CHIPPING@40K
17 posts • Page 1 of 1
CHIPPING@40K
I have a standard frst (T2 turbo) excluding s/s and d/v and the car has only done 40k.
I wanted to chip it (180BHP, which it won't be) and uprate the actuator and I do oil/filter change every 3k.
Would this give me more mid range with the remapping of air/fuel?
I don't want to go silly, and I don't want to blow the turbo but what psi do these chip's run at?
I don't want to T3 it or anything.
Also it's going to be rolled, but at the moment having had a good run, sometimes the revs drop to 500rpm at stand still and either pick up again or it stalls. Any ideas?
- TURBOHERM
I would recommend contacting Greg (Fezzy_Turbo) on the site - he has been running a 165 chip for a long time now with no complaints and I think it's fair to say his is one of the most reliable Fiesta RSTs I've known of.
- Project
- fiftyoneCL
Hello.........
Q : Also it's going to be rolled, but at the moment having had a good run, sometimes the revs drop to 500rpm at stand still and either pick up again or it stalls. Any ideas?
A : Check your idle control valve might be needing a clean, if not a sensor somewhere might be getting too hot. Need to be put on a diagnostic machine for that.
Tuning : Be sensible. You have the right idea with an new actuator (-32) and then a chip like a Superchips 165 or also know as a stage1 chip would do fine. A good tuner should take the boost upto around 12psi, that should give u a good increase in power and torque, but also not pushing things too far.
The worry i have is your car has only done 40k and probably would not be used to being driven harder. I am guessing it was a show car. If you have the patience, i would put some more miles on it as standard, driving it harder. This might give away some weak points, in other words things might break, but hopefully not.
Whats the history of the car ???
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
CHIPPING@40K
NICE ONE, CHEERS.
Iv'e already checked my idle control valve and it's totally clean and free.
I thought it might be a sensor or something. But it is strange how sometimes it doesn't happen, but as you said temp might have something to do with it. I'll find out the same time when I get it rolled.
I have been pushing it harder, but I don't drive it stupidly.
The rocker cover gasket needed replacing, and I was told that it wasn't fixed properly and sort of folded in on the back, but that's fine now.
Also had the valve stem rubbers done which stopped the smoke on cold start up so that's good and that's about it really.
It's an extremely clean engine with an immaculate body. It has had two/three previous owners (can't remember), the second previous owner had it as one of a couple cars and just brought it out of the garage to polish it etc..and the previous owner was a lady who's husband worked away, so she just used it to get it out of a garage and go shopping-quick way to get there though.
Got all MOT's and service so i'm gonna hang onto this one.
- TURBOHERM
Sounds like a good one.
Well a stage1 upgrade should keep you amused and not put too much of a strain on the engine (if it breaks dont blame me )
Get it along to a good tuner and see what happens.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- MOONDUST FRST
You dont need to buy Platinum plugs for a stage1. I use good old NGK R plugs on mine with no problems and dont bother buying expensive HT leads either, stick with Ford ones but replace them every time you replace your plugs. The heat under the bonnet does them no favours.
As for the chips i dont know, i have only experienced Superchips. I think one difference will be the price
I have had no problems with my chip apart from the begining, but was soon sorted.
Your best bet would be to shop around.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
Fezzy Turbo :You dont need to buy Platinum plugs for a stage1. I use good old NGK R plugs on mine with no problems and dont bother buying expensive HT leads either, stick with Ford ones but replace them every time you replace your plugs. The heat under the bonnet does them no favours.
Stick with standard frst plugs, change them every 6000 miles.
Greggors do you change your leads everytime you change the plugs ?? i think not lol a set from ford costs like £40, but they are miles better than supposed 'uprated' ones. Buy a set and they will last you years
- MarkFRST
Mark...
is that the type that are solid going onto the plug ? not the 2 bits of plastic that open up with the heat ? I think they are made by Bosch.
I just buy the ones that are 2 bits of plastic and i have had some horrors trying to get them off!!....here comes the lead but leaves the connector attached to the plug!!
I changed my plugsand leads when i change my oil about every 5k and having a friend in the car trade, i get my parts at trade price
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
Ive had a 165 superchip before, and then the ahmed bayjoo 165 chip which ive been running for 2 years. Not noticed much difference in them but the bayjoo is supposed to be better.
Problem is ive heard he doesnt do off the shelf chips anymore
- GavStyli
- Your car: Fiesta Turbo
TURBOHERM ::aviator: right o!
And injectors.............Uprate from the standard blue to red? Where do they sell these?
I don't need beige cus that is more for the stage 2 upgrade isn't it? and the cost!
you dont need to replace your standard blue injectors for the 165chip
anyhow the next step up from them are the beiges which cost £225 and require a 195chip
- GavStyli
Yeah all the bayjoo chips iv'e seen on the sites say that soldering is required.
I'm gonna go with plug and play!
The blue is standard, but what are the red ones for? There not as big bore as beige.
Iv'e seen that all the beige ones are on the 195bhp cars, but are the red ones for fast road or something?
They are an upgrade from the blue but didn't know if it would increase the performance with a 165 chip or even if you could put them on a standard car to give give a few more bhp?
Still don't know where to get them, but I will keep looking!
Any comments welcome for this subject!
- TURBOHERM
Red injectors
Just putting on different injectors wont give u more power, all they do is allow u to have larger amounts of fuel when running higher boost.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
Stage1
hello good people,
FRST.
Is there any difference between motorsport red and blue ht leads as I
have the red ones and might buy new ones soon?
Also can I do a resistance test with a meter to see if the old ones are degrading?
Also do I need an (uprated) actuator or just a new (fully reliable) one for my stage 1 upgrade?
FRST.
- TURBOHERM
