Clicking When Boosting!?!?!?!?!?
11 posts • Page 1 of 1
I have got a FRST & it has been running fine, I took the 165 superchip off for a week.
I have now put it back on & sometimes get a clicking/Gratting noise when the car is boosting,it dosent do this when I remove the chip.
Has anyone else had this???
- Nitrous
Project, how do I test these??
I do have a dumpvalve (Diaphram type), but no bleedvalve. The actuator does look quite old & could do with an upgrade, but I was worried that my turbs could B on its way out or at least be under strain with a new actuator holding say 12psi ??
Paul, I have got my chip securely plugged in, so I dont think it would B this, although I will check.
CheeRS!!
CheeRS!!
- Nitrous
Yeah be careful mate - if your fuels pumps weak it could be detonation.
was the chip set up on a rolling road?
take the ecu out and clean the contacts with petrol - refit and try again
Thanks 4 the advice people! I did get it setup on the RR, so I hope it does have enough fuel! I only get 130/150 miles per tank, so I think there is defo enough fuel being used.
Im getting it checked on the Rd this Sat so I will let U know what it is, hopefully.
- Nitrous
