clutch pedal advice please mk3
Postby b0yracer on Thu Apr 25, 2013 4:38 pm
my clutch pedal keeps sticking to the floor, mk3 fiesta, no other issues, ive not used car much latley, 1st time it stuck i changed the cable no difference, now ive taken the arm off ( gearbox end) and taken the rubber boot off and sprayed lots of wd40 on the shaft, which seems to have done the trick
but im confused, my clutch pedal, hasnt racheted at all since all this messing and removing cables etc, should it rachet or not???
its got a white plastic knob/screw thing on the pedal, is it a manual adjuster type?? it does have a rachet and pawl too, i dont want to take it to bits as i dont understand how it works
(though all is working fine now so maybe was just seized and doesnt need adjusting, but just curious as how this set up works)
i went to scrap yard and they have 2 mk3 fiesta in but both have a different pedal with out this white knob screw thing on it
cheers dave
b0yracer
Your car: ford
Re: clutch pedal advice please mk3
Postby b0yracer on Thu Apr 25, 2013 4:55 pm
mine looks like this
b0yracer
Your car: ford
Postby willowandmikey on Thu Apr 25, 2013 5:00 pm
If you mean ratchet like the handbrake then no. It should depress to the floor and just come up of its own accord
willowandmikey
Your car: ford fiesta xr2i 8V
Postby b0yracer on Thu Apr 25, 2013 5:07 pm
im refering to the rachet and pawl behind the clutch pedal, i thought after fitting a clutch cable the rachet would click/rachet on the first press or two of the pedal, but mines not moved at all??
cheers dave
i know once adjusted/set in place it shouldnt rachet
b0yracer
Your car: ford
Postby Tweek on Thu Apr 25, 2013 10:29 pm
Don't wanna sound n00bish but have you actually set the adjuster on the white knob?
Your car: VW Golf GTD
Postby b0yracer on Fri Apr 26, 2013 9:16 am
Tweek :Don't wanna sound n00bish but have you actually set the adjuster on the white knob?
no i dont know how you do it i cant find any info on it, even in my haynes manual
b0yracer
Your car: ford
Postby b0yracer on Sat Dec 21, 2013 9:15 pm
it was the clutch arm on the box causing this problem because ive not used the fiesta much, it was seizing up, sorted now and been using it couple of times a week
b0yracer
Your car: ford
Postby b0yracer on Sat Dec 21, 2013 9:16 pm
ps like the choice of words n00bish :lol: :lol: ive been called worse
b0yracer
Your car: ford
