coilover top mounts
3 posts • Page 1 of 1
coilover top mounts
Hi,
can anyone advise me to which top mounts/bushes are used with Gaz coilovers?? Front and rear???
Do standard bearings need to be used up front also??
Got coilovers on way but want to have all the new top mounts here ready so i can fit it all in one hit.
hope someone can advise.
thanks
thanks
- goaty
Re: coilover top mounts
i presume for a fiesta mk3.
the rear you dont need the bush in the top of the cup. just fit the cup over and put the bolt through it and put on the car.
the fronts are just a straight swap you can use the original bush but i would recommend the poly bushes as it makes a big difference on the front
- Minstral
- Your car: *
already ordered now. thanks for the info
- goaty
