Coilovers!?! Are they worth the money?
6 posts • Page 1 of 1
I know its not a Fez but i plan on getting some coilovers next weekend for my Mk4 Astra to accompany my new 18s. But ive never had them before and iv heard great things about them along with poo things... so whats the score?
- ~PhatMan~
- chumkila
- Dirty Post Whore!
Coilovers should definitely be an improvement over standard springs+shocks in terms of stiffer spring rates and controlling things like bodyroll; its nice too to be able to set your ride height to your preference so you can find a decent height to match your wheel size. Most coilovers i've seen also come with adjustable rebound/compression damper settings, so again you can adjust this to your individual taste, super-stiff for track or more compliant for normal road use
Coilovers should also have spring and damping rates which are specifically matched, this might not be the case if you bought seperate shocks+springs from two different manufacturers; however if you buy matched springs+shocks then this setup should perform as well as coilovers
Just a case of whether you want the extra adjustability (and the extra expense) of coilovers
- Snyx
