Come-On Guys
10 posts • Page 1 of 1
Come-On Guys
There must be the parts I need for my conversion somewhere. I really do need them, if you offer me parts at least give me a chance to buy them please....
So let's hear from all those people who have what I need. This is very important.....
GM)
GM)
- grandman
Re: Come-On Guys
Would help if you list what you need
- big g1985
- Your car: mk2 xr2
Re: Come-On Guys
I believe I need this list:
A. Radiator
B. Radiator Mounting Brackets
C. Radiator Hoses All
D. Radiator Cooling Fan
E. Fan Mounting Brackets
F. Thermostat
G. Thermostat Housing
H. Strut Brace
I. Engine
J. Clutch
K. Gear Box
L. Drive Shafts
M. Hubs
N. Front Brakes
O. Hand brake and cable
P. Engine Mounts
Q. gear Box Mounts
R. Inlet Manifold
S. Outlet Manifold
T. Throttle Body
U. Fuel Rail
V. Injectors and any other parts related to fuel supply.
W. Exhaust and all fittings and gaskets
X. Suspension
Y. Steering Column
z. Steering Rack
1. Starting Motor
2 alternator
3 Power Steering Pump
4. Fuel pump and sender
5. Any and All Vac Pipes, and Air Boxes bolts and nuts
6. Car Loom
7. Engine Loom
8. Fuse Box
9. Fuses and relays
10. All sensors
11. All Belts and cams
12. Air Filter
14. ECU
15. Ignition Barrel plus Pats
16. Ignition Key's
17. All locks and Keys
18. P.A.T.S ECU
19. Central Locking and Alarm ECU
20. Any Other ECUs
Thank you to anyone who can help me...
GM)
A. Radiator
F. Thermostat
H. Strut Brace
I. Engine
J. Clutch
K. Gear Box
L. Drive Shafts
M. Hubs
N. Front Brakes
P. Engine Mounts
Q. gear Box Mounts
R. Inlet Manifold
S. Outlet Manifold
T. Throttle Body
U. Fuel Rail
X. Suspension
Y. Steering Column
z. Steering Rack
1. Starting Motor
2 alternator
6. Car Loom
7. Engine Loom
8. Fuse Box
9. Fuses and relays
10. All sensors
12. Air Filter
14. ECU
16. Ignition Key's
18. P.A.T.S ECU
20. Any Other ECUs
GM)
- grandman
Re: Come-On Guys
I offered you a few parts I had left lying around but you didn't want them! It's very difficult to get everything from one place, ask anyone!
- Tweek
- Your car: VW Golf GTD
Re: Come-On Guys
The main parts I want from one place is engine, loom and ECU, the other parts I am hoping, I can get from other areas. But i already tried using an engine from one place then found getting the loom and ecu to be a big guessing game, especially the likes of sensors and idle valves ect...
- grandman
Re: Come-On Guys
You need to be more specific as to what parts from what models
I have got Zetec looms ecus cams inlets etc
Both pats and non pats setups
- big g1985
- Your car: mk2 xr2
Re: Come-On Guys
Right OK let me set out how I see it, you can then say if I'm correct or not, OK? I looking to obtain a 2 ltr Silver Top Zertec series 2, and a 1800 Escort Black top.
So basically I need any MK3.5 16v engine loom with internal EDIS (i.e. no external EDIS module). I will also need a car loom from a fuel injected model. to match the engine loom. As Far,as internal PATS go, I think a separate pats module maybe the way to go, as I would hope to get the ignition Barrel and key plus the barrel ring'
Ecu wise I believe I'm right in saying any of the following will do the job:
DEEP, DESK or DEWY.
I think I will need the following as well:
sump, oil pick up, flywheel (and clutch - must match your gearbox type), inlet (alloy type, ideally from an RS1800 or XR3i 130PS, not late Escort plastic type - I need a a 1.8 one at least, with matching injector plate), water pump, water pump pulley, there's probably more. (Uncertain about all the sensors I will require to make this work)
I think I will also need a CVH alternator and Zetec pulley if I use a CVH alternator mount, or simply a Zetec alternator if I use a Zetec mount. Ideally I'd want a Fiesta one -That is another reason for External PATS. Not sure If i will need a PATS mount. If not, a a mount from a MK3 Fiesta 16v, i.e. XR2i 16v or RS1800 (early).
This is what I've been informed of, and will need more I think, in fact I'm sure I'm going to need quite much more... but hope this provides some direction for you to see...
Regards
Dave)
DEEP, DESK or DEWY.
Regards
Dave)
- grandman
Re: Come-On Guys
I've got a couple of the Efi zetec inlet manifolds birth ho 130 and so
Also will have a sump flywheel and pick from a silver top 1.8
- big g1985
- Your car: mk2 xr2
Re: Come-On Guys
On Facebook on the fiesta mk3 rs group, there's a guy nick shorter that's breaking two mk3 zetecs a si and rs 1800
Your other option is to buy a whole vehicle which may be cheaper in the long run
- reithy
Re: Come-On Guys
big g1985 :I've got a couple of the Efi zetec inlet manifolds birth ho 130 and so
Thank you Big, I still need some parts. Most notably a gear box cradle and two engine mounts, and offers...
Regards
dave
- grandman
