cossie brake conversion.
37 posts • Page 1 of 2 • 1, 2
im wanting to convert my si to cossie discs and pads (ready for the ..... )
am i right in saying that i need 4wd callipers and 2wd disks? wot pads should i use? shall i buy grooved disks?
also as mine is a 1.4 si will the callipers fit the same as a mk 3?
also do u reccomend doing a rear disc conversion? if so does anyone wanna earn some extra £££££ by fittin em for me? (project ?)
- Mexi
Right - as for the rear conversion, Have got all of the parts from an RS2000 to fit to mine!
Fitting dont look to hard!
For front, i think that you need 4wd calipers and disks! ( i hope, just ordered some!!)
If you want i can email you a scaned FF with instruvtions of how to fit the above.
Just give me a shout!
James
James
- xrsi
- XR(ustyAtTheMo)SI
Use Mondeo ST24 discs, not Cossie discs - the offset of the Cossie discs is wrong which is why you have to space the caliper out, whereas the Mondy discs should go straight on.
- Project
- fiftyoneCL
Exactly the same size as Cossie discs - I suspect they're an evolution of the Sierra Cossie kit which was gonna be the Mondy Cossie, but which was never made.
Mondy Ghia Si 4x4's use Cossie running gear too I think...?
- Project
- fiftyoneCL
what size wheels you gotta be running to squeeze mondeo st24 discs behind them ??? 15s ??, i am running 14s, would St24 discs and cossie calipers fit on ok ???
i wanna give me Si some more stopping power
Xander
Xander
- xander7
15's is the absolute min for cossie breaks!!
If the ST24 disks are the same size, thenn unfortunatly you will need 15's!
- xrsi
- XR(ustyAtTheMo)SI
its the caliapar that needs the clearance, disc size not important as long as they fit the calipar
- fiesta_fras
- Elite Poser
most motor factor stores can give detailed info on disc sizes, dimensions etc, ill check tm
- fiesta_fras
- Elite Poser
On 2002-03-26 18:22, xander7 wrote:
damn, looks like it is a simple uprate of the discs and pads for me then, i can't afford bigger rims for a long while.
EBC pads and Grooved discs it is then
Xander
I have a set going complete with calipers from an FRST, have only been on car since aug and have pleanty of life in the pads due to not great seal of mileage being done!
They are :- Green stuff pads, 8 grooved vented (not x drillled) disks and FRST calipers,
Yours for say £70?
James
- xrsi
- XR(ustyAtTheMo)SI
Would the same conversion work on a mk 4? Mine are solid 12mm thick discs. Was thinking of going for a big disc kit (like a 285mm) from hi-spec, but dont know if the standard callipers can be used with thicker vented discs (eg 20mm). And I don't really want to spend another 400 bucks on callipers.
Anyone got any suggestions??
- higham
ian.
are you useing green stuff pads?
they are that hard ,hence no dust that all the heat goes into the disc hence warping them.
project st2000.
what is the price difference between the st24 discs and cossie ones?
cheers guys.
daz
project st2000.
cheers guys.
daz
- daz
Right then, can someone tell me exactly what you need to do this, as I want to upgrade the brakes on my car. The car is a 1.1 mk3.5. I know what your going to say but I want them ready for when I get some turbo power.
Coming soon!!!!
- icecool
So.... You need mondy st24 discs, 4wd cossie calipers......and what else? Longer bolts I presume? What we need is a exact list of everything needed, so we can all rush out and buy the bits to do it
God knows I want lovely big discs on mine!
- ~nomad~
- Your car: Breadvan
Higham - Mk4 calipers came in two lengths I think. As long as the caliper bolt spacing is the same (I should think it is), you won't have a major problem fitting them. Pad hardness contributes to disc warping but the main factor is how much heat the pads can dissipate through themselves, as well as their friction coefficient (I don't understand either - basically just how grippy they are). Get out there with a ruler and a jack and have some fun.
Daz - ST24 discs are the right offset for the calipers and you therefore don't need to use 5mm spacers on the bolts.
- Project
- fiftyoneCL
- MOONDUST FRST
Has anyone here actualy got cossie disc and calipers on? If so what are they ie 278mm cossie 4x4 front discs with 2wd calipers etc. It seems everyone has an opinion but to save more expensive mistakes (like ianfrst buying a set of st24 disks that dont fit) can we hear from people who have done the conversion and know what parts they used.
Im not having a go at anyone. I just dont want to order a new set of grilled and drooved (?) discs and new calipers to discover Ive wasted me dosh!
- ~S1~
- Hold On...
I've fitted Cossie 4x4 callipers AND discs to my car. It's not exactly a FRST, but the running gear is standard FRST.
The 2wd discs have the wrong offset on them which means they don't fit.
Regards,
Stephen
Regards,
Stephen
- Quantum
S1 :Has anyone here actualy got cossie disc and calipers on? If so what are they ie 278mm cossie 4x4 front discs with 2wd calipers etc.
Why not PM Cubby, that's exactly what he's got on his 240.
- Mulder
