cossie brakes???
12 posts • Page 1 of 1
cossie brakes???
Is it true that the cossie callipers fit straight on to a Fiesta, (RS1800 in particular)
- Shug
- chumkila
- Dirty Post Whore!
- chumkila
- Dirty Post Whore!
You'll need washers to space the caliper out a bit from the hub. And also, because of the extra distance the spacers make, you'll need longer bolts to do the job properly. Apart from that it's a direct fit.
I've got cossie front calipers and discs under my 15's. It is a tight squeeze but I've had no problems so far, so you'll be fine with 16's.
- DuncanFRST
Get some braided hoses to go with the new calipers, but go for the stainless steeel fittings as the plated steel ends rust too quickly. It's worth the extra £15.
Regards,
Stephen
Regards,
Stephen
- Quantum
