cossie fuel pump on 2.0 fezzy?
5 posts • Page 1 of 1
i've got a 2.0 fezzy and would like to know would it be worth fitting a cossie fuel pump? would i get better performance?
cheers guys
cheers guys
- dee_RS_2ltr
You only need to upgrade the pump if the current one isn't supplying the injectors enough. If that were the case, the engine would be running like rubbish when you put your foot down.
its a rs1800 pump. it works fine with the 2.0 may have to upgrade then when its a 2.1 turbo but then again it might be fine.
- dee_RS_2ltr
