Cossie injectors.
5 posts • Page 1 of 1
Hello people,
Was wondering if i could use escort cossie injectors in conjuction with a 195 chip, instead of using beige 701's. I know i should probarly use 701's but at 60 quid a pop, its quite expensive. Also can i use a cossie fuel pump instead of a uprated fiesta turbo one?
Any advice would be appreciated.
- EvilFranky
I think the idea of an uprated FRST fuel pump is to use an actual cossie one anyway..........i maybe wrong
as for the injectors, will they fit ??
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
Uprated fuel pump(Facet I think) £100ish from Amber. Just have to swap the pump units over.
The injectors run at a different ohm, I know someone on here was running cossie stuff without a problem, but i should stick to the 701`s
- snake
- Trainee Burger Flipper
- Your car: ford
The cossie ones are different ohms, if you want them i think you have to get cossie management..
Uprated fuel pump is what it is mate, i have one and beiges, i managed to run 19psi with perfect fuelling and could still of gone more if the engine could of taken it.. Like People say the beiges are good for 230bhp..
- Ian C70T5
- Das Ist Kapput
unless you have the program on the chip changed you can`nt use the cossie injectors because they work at a different voltage to the fiesta management system. the just car just won`t run probably the fiestaturbo fuel pump is good for 200 bhp or 18 psi with a standard turbo. i`m running a 1.9 cvh stage three T3 stage three big valve head kent cvh35 i have got cosworth management with dark green injectors and a uprated escort cossie fuel pump because i`ii be switching between 14-22 psi
- alex76
