cossie management
5 posts • Page 1 of 1
cossie management
So ive got OFAB on my ECU......
does that mean i can run cossie management????
if so,then....
what bits will i need?
is a simple job?
if its not a simple job, who can i ring to get it dun?
and last off, what r the benifits of the conversion?
CheeRS bezo
if so,then....
is a simple job?
CheeRS bezo
- bezo
- Your car: The ratfez
i`ve got cossie management on mine does not matter which ecu you are running to fit cossie management your old loom will be ripped out anyway
why do you want cossie management the ofab loom can be made to work with a 3 bar map sensor and you can get it to work with different injectors etc no need for cossie management yes there is loads of advantages to having cossie management but not loads over the fiesta management ahmed bajoo and stuart at the motorsport developments can map the fiesta management to produce big power.
- turboboss
- chumkila
- Dirty Post Whore!
i know its not a fiesta but jamsport did me an off the top of there head quote for cozzy management on my erst and they said £2000! the ford ka with erst engine in rsoc day pics in this months fast ford is cozzy managed it was also at fitp too!
- RS RUDEBOY
