Cossie rear brakes on FRST
6 posts • Page 1 of 1
Will Cossie RWD or 4x4 rear calipers/discs etc fit on a FRST without too much grief?
- O'
From experience rear disc conversion are more trouble than they are worth. The drums are more than up to the task of stopping the car and work, why interfere?
I do tend to agree in large with what Fast Ford print especially over the last 12 months where they have really lifted their game and now produce a superb mag.
The rear disc thing is just something I'm still not even vaguely convinced about. I'm quite happy to be proven wrong, but until I do see and experience a properly working rear disc conversion that hasn't had bias valves or posh pedal boxes added I will continue to advise against their fitment.
The Cosworth front brake conversion is superb You will need to use 4x4 calipers and discs and iirc 5mm spacers to bring the caliper out to the correct position. Depending on your choice of wheel you may have issues with the wheel weights catching on the caliper
