Cossie T3
7 posts • Page 1 of 1
Cossie T3
Hi does anyone know what cossie to get the t3 off to fit a frst engine? does it make a difference.
also what is the spec of a standard cossie t3, and what makes it different to an escort t3.
cheers Tony
cheers Tony
still need to update this sig
- ~Tony~
Re: Cossie T3
TonyBlackFRST :Hi does anyone know what cossie to get the t3 off to fit a frst engine? does it make a difference.
cheers Tony
just guessing at things here but would it not be the compressor side of the turbo thats different. giving a bit more puff to the turbo.
- edders
hello mate ..i have a 4x4 cossie turbo on mine .i used the exhaust housing of a s1/s2 so internally the cossie is the same on that side. the compressor side is bigger internally.. the benifits over a normal t3 i dont know ....the 4x4 was going begging when i needed a turbo
- FRSJON
there water cooled,the cores are the same as a s2 one ...i used the s2 exhaust housing so that it mated to my exhaust without mods....the cossie housing needs a custom down pipe being made
- FRSJON
Normal Cossie ones have a larger exhaust housing i believe.
4x4 Cossie turbos are a bit more different though, using a larger inlet and exhuats housing making them the equivalent of stage 2 turbos techincially. As stated they can flow over 300 happily.
- XRT_si
