cosworth brakes on the frst
3 posts • Page 1 of 1
hi i've obtained some 4wd sierra cosworth calipers that i plan to put on my frst. what discs do i need that would be the easiest to put on? seirra cosworth 4wd discs or escort cosworth discs? or don't it matter?. also wot modds are required to fit these? i heard longer bolts and some washers of some kind?
- louma84
i have got cossie 4x4 calipers disc's, pads and pads and they go on easy peasy
take the caliper off the carrier fit the disc's and try and get them flush to the hub
then like you said all you need is longer bolts and washers
cause all is putt the carrier over the disc and use the washer to space the carier even at both sides over the disc
so it doesn't foul the disc
they stop like fook but lock up fairly easy
hope this helped
hope this helped
- Keneth
