cosworth brakes ???
3 posts • Page 1 of 1
cosworth brakes ???
I've read in one of the parts for sale posts, that someone was selling
cossie brakes with xr2i calipers. Is it is possible to use these calipers with
cossie brakes ??? Or for a true conversion will pukka cossie calipers be
better ??
I ask because I've got an 89 xr2i and am thinking of upgrading the
brakes to cossie / rs2000 in the near future.
better ??
- GXr2i
Aren't Cossie rotots 25-30mm in thickness? 2i rotors are only 20mm, so the answer's no unless you do some hefty mods, and then you will have to make a 5mm spacer/extension bracket up as well as far as I know.
- Project
- fiftyoneCL
cossie brakes are best
very cheap too
in comparison a 4 pot kit will cost you arround £1000
cossie disks £150
cossie pads £70
Cossie calipers £120 recond i paid for mine
£5 for washers and bolts
£30 for braided brake hoses
job is a good one
ive also replace my master cylinder and brake linkage more due to the fact i was bored than to improve braking
but they now stop spot on
if you aint got abs be very carefull with them
very cheap too
cossie disks £150
cossie pads £70
job is a good one
- MadcatCraig
- BANNED SELLER
