Cosworth intercooler conversion pics (56k unfriendly)
51 posts • Page 2 of 2 • 1, 2
how much did graham charge you for the modifications to the intercooler dude? oh and you've done a top job there mate
- Hardeep_911
Its just that i allways see em on tacky cars, people think they make a car look posh/expensive and so they get stuck on a-reg sierra's with 5-spoke chrome trims... whats all that about...
Just dont think that sorta thing should be on a nice car, a plate is a playe, dont make it bigger thatn it needs to be,
Look at the pic in the sig, plate is huge...
- AndyRS1800
Hardeep_911 :how much did graham charge you for the modifications to the intercooler dude? oh and you've done a top job there mate
£70
Including labour, materials and shipping. I cannot recommend him enough!
Andy my car had a feature in Max Power
- Stoned
I know it did, because of the plate... only messin, that was when maxpower was good, now its all 1.2's with biggest kit ever...
- AndyRS1800
Looks good.. looks pretty good.. hope the IC gets enough airflow THRU it.. due to the fact that is is mounted in front of a panel
Clearing it about an inch of this panel will allow more air to pass the IC.
- Jur
Hi Chris,
Thank you for your kind comments much appreciated , it was a pleasure to help out, nice installation too!!
Graham
http://www.grsmotorsport.co.uk
Graham
Grahamx
- Grahamx
Looks Great...I want one! but...I have always prefered the FRST Fan...
though is the XR2i fan any better as I always thought the FRST fan shifted more air?
R.I.P Rob...
"The Teenage Chicks Love The Car"
- TrekkieFRST
- Location: Kings Lynn Drives: Honda Prelude Sex Appeal: 52.30% Loves: Stuff!!!
The XR2i fan seems to shift a spork load of air, and the drain appears to be bigger on the system as the revs drop lower with the XR2i fan on idle than it used to with the FRST fan
It does seem very effective. The rad core is cold where the fan is pulling air through.
I think my original assumption was correct in that Ford only went for the front mounted fan on the FRST because there was no room for a rear one with the turbo and therefore the heat on the back.
I suppose a good test of which is better is to find out what the ERST runs. Having a bigger engine bay the rad might have a rear mounted fan on it.
- Stoned
I do believe the ERST has front fan
I do have the fan outta my XR2i...may have to have a look into it
R.I.P Rob...
- TrekkieFRST
Cool man, but it wont fit unless you have things like my setup or similar which is to say:-
a) Rad is on T3 mounts so moved further forward than normal and...
b) there is no charge pipe running from the turbo to bottom of IC like on normal FRST layouts.
It's only because of this it fits. I did try and get a decent overhead photo, but the gloomy english weather we are currently having put paid to a clear photo.
- Stoned
yeah keep the plate where it is, i think that car will be running a lot cooler now with that big Rad in it. Just one thing, have you protected the metal you cut away? Don't want rust.
- MikeyXR2i
