CPS Location - FRST
CPS Location - FRST
Postby AR-FRST on Fri Apr 18, 2014 7:24 pm
Hi Guys,
Does anyone have a photo of where abouts the CPS is located on a (EFI) Fiesta RS Turbo?
I'm not getting any spark. I've removed the plugs & they are bone dry.
The Fiesta has fuel & a brand new fuel pump was fitted 3 months ago. The pump can be heard priming when I turn the ignition.
AR-FRST
Your car: Fiesta RST
Re: CPS Location - FRST
Postby mikeymikeyp on Fri Apr 18, 2014 8:19 pm
check your getting a spark ,the cps is behind the starter i think its a wee torx screw holding it in
mikeymikeyp
Postby AR-FRST on Fri Apr 18, 2014 8:35 pm
As stated above "I'm not getting a spark"
AR-FRST
Postby AR-FRST on Fri Apr 18, 2014 8:37 pm
Once I find the CPS, can it be tested?
AR-FRST
Postby AR-FRST on Sat Apr 19, 2014 10:37 am
Found it.. How do i test if it's working?
AR-FRST
Postby Boostjunky on Mon Apr 21, 2014 2:41 pm
Is fuel pump priming when you turn the ignition on ??
Boostjunky
Your car: Ford
Postby AR-FRST on Mon Apr 21, 2014 6:27 pm
Boostjunky :Is fuel pump priming when you turn the ignition on ??
Yes
AR-FRST
Postby Boostjunky on Mon Apr 21, 2014 9:47 pm
Can you see the tacho moving whilst starting car ???
Boostjunky
Your car: Ford
Postby Boostjunky on Mon Apr 21, 2014 9:49 pm
to test if the cps is working ok follow these steps
ingnition off
disconect the cps sensor
check resistence on the cps terminals
should be 200-450 ohms
Also wiring to the sensor usually goes brittle worth continuity testing it back to ecu plug to check
Hope it helps
Boostjunky
Your car: Ford
