Cracked T2 Turbo manifold
Postby jammy86 on Thu Apr 04, 2013 7:57 pm
Evning all!
Both the T2 exhaust manifolds I have are cracked :( Is there anything that can be done to these to fix them? If not what are my alternatives? Does anyone make custom T2 manifolds? I need it to be a perfect replacement. I dont want to go T3 as I'll need a new radiator (this is fitted in a Ka) and I am more than happy with my T2 hybrid which only has a few hundred miles on it.
JAmes.
jammy86
Your car: KaRST
Postby Pastieman on Thu Apr 04, 2013 7:59 pm
Can't you get them welded
[/url]
Pastieman
Your car: Mk3 Fiesta Rs Turbo
Re: Cracked T2 Turbo manifold
Postby jammy86 on Thu Apr 04, 2013 9:38 pm
Have heard of it being done on a NA manifold, not sure about a turbo one as it's taking a lot more load. If anyone has had it welded how was it done and was it sucessful? It doesn't look like the easiest position to get to.
jammy86
Your car: KaRST
Postby reithy on Thu Apr 04, 2013 9:45 pm
Strange, can you post a pic so I can see what you mean? I can have a look as I have a few t2s kicking around your on about the exhaust manifold that bolts to the block and the turbo mounts to this?
reithy
Postby jammy86 on Thu Apr 04, 2013 9:52 pm
Yes, where the cylinder 1 primary meets the next along they have both split at the root. I'll try to get a picture tomorrow, i'm fairly sure it's a common fault.
jammy86
Your car: KaRST
Postby crazycage on Sat Apr 06, 2013 10:13 am
if you send me the t2 manifold i can build a custom stainless steel tubular one
crazycage
Postby jammy86 on Sat Apr 06, 2013 12:19 pm
Hello,
I've replied to your other thread. Thanks,
jammy86
Your car: KaRST
