crank sensor
crank sensor
Postby fiestajim23 on Mon Mar 17, 2014 6:47 pm
Hi guys trying to learn as much as I can about my frst so my latest question what are the symtoms of a nackered crank sensor all advice welcome cheers jim
fiestajim23
Your car: Fiesta RS Turbo
Re: crank sensor
Postby mikeymikeyp on Tue Mar 18, 2014 1:30 am
no spark
mikeymikeyp
Re: crank sensor
Postby jayrs on Tue Mar 18, 2014 1:47 am
As above, ecu won't read the crank position and won't fire a spark
Re: crank sensor
Postby fiestajim23 on Wed Mar 19, 2014 3:09 pm
Ok cheers guys
fiestajim23
Re: crank sensor
Postby mikeymikeyp on Thu Mar 20, 2014 11:59 am
take the crank sensor out mate and give it a clean and a wee wipe on the sidewall of your tyre that cleans them much beter than a bit of sandpaper which makes them a wee bit shorter but it does matter with something like that
mikeymikeyp
Re: crank sensor
Postby fiestajim23 on Sat Mar 22, 2014 12:41 am
Thanx guys had it cleaned and wiring sorted seems to be runnin a lot better still getting the odd splutter how tight [ERRR] the throttle cable be at the inlet send sorry for sum of the technical terms ha cheers jim
fiestajim23
Re: crank sensor
Postby jayrs on Sat Mar 22, 2014 9:05 am
