creamy dipstick
creamy dipstick
Postby fiestajim23 on Wed Feb 12, 2014 7:18 pm
Hi guys creamy deposit in the dipstick tube on my frst changed the oil nothing in it nothing in the oil filler cap advice please cheers jim
fiestajim23
Your car: Fiesta RS Turbo
Re: creamy dipstick
Postby Boostjunky on Thu Feb 13, 2014 12:23 am
Have you driven it much lately/and or driven it for short trips , if so it may not be a head gasket it may just be condensation buildup as it happens when car doesn't get chance to get to fullworking temps to stop it building up
If that makes sense lol
Boostjunky
Your car: Ford
Re: creamy dipstick
Postby fiestajim23 on Thu Feb 13, 2014 8:15 am
hi mate it hasn't been driven that much short 15min journeys really.
fiestajim23
Re: creamy dipstick
Postby Boostjunky on Thu Feb 13, 2014 10:34 am
If it runs fine ,no overheating or blowing water out from header then I would think that's all it is
Sounds just like its condensation from small runs ,lots of cars suffer with this due to the breather setup as short runs do t give the motor chance to clear it all out with small runs
Boostjunky
Your car: Ford
Re: creamy dipstick
Postby FRSJON on Thu Feb 13, 2014 1:41 pm
as above,dont worry about it... a mate had one where the whole under side of the rocker cover was creamy..changed the head gasket and there was nothing wrong with it :lol:
FRSJON
Re: creamy dipstick
Postby fiestajim23 on Thu Feb 13, 2014 1:51 pm
Ok guys thanks for the replies.
fiestajim23
Re: creamy dipstick
Postby fiestajim23 on Thu Feb 13, 2014 6:33 pm
Me again just noticed the expansion tank for the radiator is frothing up not overheating on the guage tho is it looking like the head :( jim
fiestajim23
Re: creamy dipstick
Postby georgiocat on Thu Feb 13, 2014 6:50 pm
If you have such signs,I am afraid you have some minor problems with the headgasket.What is said regarding condensation is correct,but if you see foam in the expansion tank,or do an oil chang and after some time the oil is creamy,there is a chance that the headgasket has some minor crack.How is it idleing?Do you see vapour from the exhaust much longer than what it was before?Also,try something more...with the engine running and the expansion tank cap screwed,if you rev the engine,does the water level in the expansion tank rises?There is a test you can do to see if there is damage to the headgasket,although it has some error margin...you must buy this : http://www.ebay.co.uk/itm/BLOCK-TESTER-UNIVERSAL-CYLINDER-HEAD-COMBUSTION-LEAK-GASKET-DAMAGE-TEST-/290937720560?pt=UK_Measuring_Tools_Levels&hash=item43bd3d4ef0
It "sniffs" traces of combustion gases in the coolant.
My Ford Escort ride
georgiocat
Re: creamy dipstick
Postby fiestajim23 on Thu Feb 13, 2014 7:09 pm
Hi yes the water level does go up and down when you rev the engine I have a spare engiine with a head which I've had skimmed and checked had a compression done on the engine that's in at the moment an the readings were good any ideas how much it would cost to change the head cheers jim
fiestajim23
Re: creamy dipstick
Postby FRSJON on Thu Feb 13, 2014 10:17 pm
fiestajim23 :Hi yes the water level does go up and down when you rev the engine I have a spare engiine with a head which I've had skimmed and checked had a compression done on the engine that's in at the moment an the readings were good any ideas how much it would cost to change the head cheers jim
where abouts in the country are you ? cvh engines are very easy to work on
FRSJON
Re: creamy dipstick
Postby Boostjunky on Thu Feb 13, 2014 10:30 pm
Get a Haynes mate and give it a crack yourself its honestly not that hard to do a head gasket at all if needs be ,and if it is frothing then it might be worth checking it with a sniff test first , this will tell you if any exhaust gases are in your water/header tank and will confirm the worst if it is hg
Boostjunky
Your car: Ford
Re: creamy dipstick
Postby Boostjunky on Thu Feb 13, 2014 10:35 pm
Just noticed your earlier post about the heaters blowing cold on the 31st ,usually this is the first indicator it could be hg along with your current creamy situation ,no pun intended lol
Get a sniff test like the link that was posted and see what it says
Boostjunky
Your car: Ford
Re: creamy dipstick
Postby Boostjunky on Thu Feb 13, 2014 10:36 pm
Oh and forgot to add I would also check your thermostat is opening and closing correctly in a kettle as this can cause all sorts of issues if it doesn't open and close as it should
Boostjunky
Your car: Ford
Re: creamy dipstick
Postby fiestajim23 on Thu Feb 13, 2014 11:58 pm
Would like to have a go myself but its my daily for work so I try and get the jobs done when I'm working away in case I do any damage lol. Its had a new stat and been good as gold for the last 5 months I'm in grimsby and there doesn't seem to be any places that no about these cars
fiestajim23
Re: creamy dipstick
Postby georgiocat on Fri Feb 14, 2014 9:05 am
Thermostats cause a lot of troubles when stick...but since you say it is relatively new,I don't think it would create problems.I would also check the cooling fan switch and plug.Due to heavy load it tends to burn out internally,it frays the contacts,and unfortunately you notice it when it is already late.Now,regarding headgasket replacement...If you have a decent set of tools,and you can make some basic thing on your engine,for example a cambelt replacement,it is easy to do it.CVH's are simple engines,they need basic mechanical knowledge.Further that,this is a good way to learn your engine,if there isn't a reputable garage to your place,as far as I see it,the risks of leting others do the replacement is a weighted risk.Perhaps if you do it by your self,following instructions carefully,you will do a better job,since the car is yours,that's so simple... :)
My Ford Escort ride
georgiocat
Re: creamy dipstick
Postby mikeymikeyp on Fri Feb 14, 2014 1:24 pm
it really not a hard job to do just buy a desent gasget a ford one if u can
mikeymikeyp
Re: creamy dipstick
Postby fiestajim23 on Fri Feb 14, 2014 2:08 pm
It seems to be playin up since I put coolant in it seemed to be ok with just plain water will have to drain it an put sum water back in and see what happens cheers for the advice guys
fiestajim23
Re: creamy dipstick
Postby Boostjunky on Fri Feb 14, 2014 4:02 pm
Did you check the "new " stat before you fitted it ?? Only ask as recently bought 3 new ones for cars I have and surprisingly two out of the three didnt even open ,well one did very slightly and the other stayed shut
If you didn't check then for the hassle involved would certainly whip it out and get it in a bowl of boiling water and check it opens as if ya don't it may just kill any new gasket you put on the car aswell :(
And you can get the head gasket done in 4-5 hrs DIY no probs
C'mon guys no one near this chap willing to help out ???? Am miles away or would have come and done it for ya
Boostjunky
Your car: Ford
Re: creamy dipstick
Postby georgiocat on Fri Feb 14, 2014 5:02 pm
Good idea about the thermostat...I would try the "new" one also.If you need a new headgasket,Ford's ones are Payen head gaskets as far as I know.Regarding help,I wish I was near you m8.I would gladly help you,but unfortunately,I am not just far,I am in another country,I am from Greece! :lol: Although as I often say,I live in the wrong country,well at least for what's involved in Fords :rolleyes:
My Ford Escort ride
georgiocat
Re: creamy dipstick
Postby fiestajim23 on Fri Feb 14, 2014 8:04 pm
Hi guys I put a new stat in but there seemed to be a lot of pressure and heat around the housing area so I left it out whie I bought a low temp one stripped the rad off flushed it thru put the new low temp one in filled it up with just water and its been fine put sum coolant in before xmas now it keeps frothin up showin normal on the temp guage.
Thanks for the offers tho guys lol
fiestajim23
