Cv grease measurement
7 posts • Page 1 of 1
Does anybody know how much grease the driveshaft joints take on a fiesta rs turbo??
Is there any reference guides to find this out??
Thanks, Edd.
Thanks, Edd.
- RS EDDIE
Re: Cv grease measurement
If its new them a glob in the boot should be suficent but second hand as much. As you can get in there but use cv grease and pack the cv its self
- mikeymikeyp
If it's new they usually come with an appropriate amount in sachets in the box.
If it's 2nd hand then I lob as much as I can get in there after cleaning it out thoroughly.
Nothing to see here...
- andymac
- Elite Pie Master
They aint new, but been totally emptied of all grease in the powdercoaters so they are now bare.
Ive got 4 x sachets that come with the cv boots so ill use them but was just wondering if more is as bad as less, in the case of driveshafts cvs?? Can one put too much grease in them???
Thanks for the replies so far tho.
- RS EDDIE
Last ones I got came with two packets in each box, if that helps.
- andymac
- Elite Pie Master
1 sachet per cv joint is sufficient, if you put too much in the pressure can force it out of the end of the boots and make a mess as it splatters over everything in sight!
- FRS_Steve
Nice one thanks pal.
- RS EDDIE
