CVH alternator on Zetec Engine - which bracket?
3 posts • Page 1 of 1
I've done search and found that on Zetec engine can put CVH alternator, but only with XR2 alternator bracket. Is CVH alternator can be used with ather bracket than XR2, cause I can't source one from XR2? May be CVH one?
Sorry for my bad english...
- disc
hi i had this problem so i bought a package from trust electrical which constists of
alternator
bracket
belt
alternator
bracket
belt
- Mikee_RS
Car: 1995 Ford Fiesta
ive found the best method so far, is to use the std escort alternator bracket. Machine the 4 mounting holes into a +/- sliding tollerance 10mm so you can move the bracket about to get the best angle for the belt.
Also a re-worked tensioner arm would be a good idea.
- TILLIO
