CVH Engine rebuild
1 post • Page 1 of 1
CVH Engine rebuild
Im currently building a cvh carbed engine and i am having some troublegetting piston rings. the piston measures 82.5 on the skirt and on the top says that the piston is a 0.75mm oversize. So that makes the standard 81.75mm The piston itself im told looks like a mfi normally aspirated one, which would be used as they are slightly higher comp. im wondering if ive stumbbled upon a 1.9 by accident. The part number on the conrod is RF-E7EE-AB
Any comments or help.If you know what sixe pistons are used in a 1.9 or 2.1 even. Best companies to try.
- Spanthefestaman
