CVH engine, throttle body manifold, Carbs
Postby Westie on Tue Jan 06, 2015 6:00 pm
Hi Chaps,
Engine upgrade means I have a few bits to let go.
Complete Ford 1.6 CVH engine, October 1988, as lean burn was post 86 I'd say it is lean burn. The cam is Burton BFX 2359. Including twin 40 DCOE carbs and manifold, fast road cam, setup to the engine, alternator plus mounting bracket. Flywheel and clutch to fit a type 9 gearbox. I've done about 3000 miles with it, since it was fitted into my Westfield over a the years. £500ono (Collection from Margate can be brought up to Epsom for £40)
Twin 40 DCNF carbs with manifold, never used these, and sat silently on a shelf. £250ono + p&p or collection from Epsom
Throttle body manifold for Jenvey to Zetec, 95mm diagonal measurement from back to front (about 82mm horizontal) 100+p&p (or collection from epsom)
CVH head gasket 6+p&p (or collection from epsom)
CVH exhaust gasket 5+p&p (or collection from epsom)
AnDy
Westie
Re: CVH engine, throttle body manifold, Carbs
Postby SLEEMAN on Tue Jan 06, 2015 11:44 pm
so to confirm that jenvey manifold is the angled version? if so any pics from side views etc
and best price on the manifold plus delivery?
SLEEMAN
Postby Westie on Wed Jan 07, 2015 11:03 am
I'll take a side view tonight, the manifold is new, fitted it to my westfield, couldn't close the bonnet properly, took it off again. Where is it being posted to?
EDIT: Should have read the location before replying :)
AnDy
Westie
Postby SLEEMAN on Wed Jan 07, 2015 7:40 pm
did you need a new manifold or have you got one as I have got a dunnell zetec throttle body manifold that's more suited to fit the tb's horizontally??
SLEEMAN
Postby Westie on Wed Jan 07, 2015 10:18 pm
I bought another one from burton that was a very very shallow one, otherwise we could have swapped :)
EDIT: will check postage tomorrow for you.
Westie
Postby Westie on Thu Jan 08, 2015 4:07 pm
Postage is £11, special and next day
AnDy
Westie
Postby tnjwalker on Thu Nov 05, 2015 8:11 pm
Hello - I realize your post is a bit aged but wondering if the CVH manifold and DCNF carbs are still available. I'll be in the UK next Wednesday to Saturday to come pick up.
tnjwalker
Your car: Morgan 4/4 with CVH
