CVH flywheel size?
3 posts • Page 1 of 1
CVH flywheel size?
Hi there!
Can someone tell me the size of CVH flywheel? Cause I'm building ZT - 1.8 Zetec from mondy and I got flywheel on that Zetec. I'm plan to use my CVH gearbox, but I'm not sure will Zetec flywheel fit or not? Mondy Zetec flywheel size is 280 mm. I know i can still use my CVH flywheel (with the bolt holes opened out to 11mm - as Jim Hearne's Quantum site says) but if Zetec one fit ...
Thanks.
Thanks.
Sorry for my bad english...
- disc
- disc
You can use the 1.8 flywheel from the zetec in a fez gearbox
The sizes are the same only the 2 liter zetec flywheel is different then the zetec 1.6 and 1.8.
The cvh one is the same size but the bolt holes are a bit smaller then the zetec one
greets Tazzie
greets Tazzie
- Tazzie
