cvh gearbox identification
Postby cossiemark on Sat Dec 27, 2014 4:43 pm
Hi how do you tell the difference between all the cvh 5 speed gearboxes? I will need a RS turbo box a diesel box and a xr3i box does anyone have all the codes/part numbers for these? Cheers mark
cossiemark
Re: cvh gearbox identification
Postby JasperJ on Sat Dec 27, 2014 7:55 pm
cossiemark :Hi how do you tell the difference between all the cvh 5 speed gearboxes? I will need a RS turbo box a diesel box and a xr3i box does anyone have all the codes/part numbers for these? Cheers mark
Usually a metal tag is attached to one of the Housing nuts, if you can still make out the no's I can identify it from that :Q
JasperJ
Postby cossiemark on Sat Dec 27, 2014 8:05 pm
JasperJ :Usually a metal tag is attached to one of the Housing nuts, if you can still make out the no's I can identify it from that :Q
hi I've not got any of the gearboxes yet I want to know what to look for before I go and buy anything so I don't get ripped off..
cossiemark
