CVH OIL FILTER ON ZETEC
9 posts • Page 1 of 1
what is the benefit from using a CVH oil filter on my 2.0 Zetec?
- frostie
oreet well i just fitted the mondeo one and it fitted fine but it was a motorcraft one but i changed the oil yesterday and used a CVH oil filter which was tiny compared to the ZETEC so there was no advantage from using the CVH.
I spent a bit of money on engine flush and i replaced my oil with MILLERS OILS well recommened!
what other oils do people use on here which engine?
- frostie
i used hof266 i think thats it, renny 5 filter, about 1.5inch tall
just needs to be changed more often :S
- JayC
Re: CVH OIL FILTER ON ZETEC
frostie :what is the benefit from using a CVH oil filter on my 2.0 Zetec?
The benefit is that when doing the engine conversion you dont need to swop the oil pump to the fiesta item.
If the oil pump was swopped when you converted it there is no benefit.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
yes it was swaped to the fiesta item so saved my self owell saves weight lol (anal)
- frostie
Sure, but as said previously you will need to change it more frequently.
- Ollybee
