cvh to zetec engine swap
Postby rsturbonutter on Fri Feb 14, 2014 6:34 pm
Am about to swap my engines over from cvh turbo to zetec turbo using a silvertop. I have got an inlet adapter from jano oddkidd. I got a thermostat adaptor plate. I am using my current rs setup. Is there any mounts I need to change or pipework of any sort as I want it up and running in a weekend
rsturbonutter
Your car: Fiesta RS turbo
Re: cvh to zetec engine swap
Postby mikeymikeyp on Fri Feb 14, 2014 7:24 pm
I just done one mate the other way around , I had to change the engine mount and mod a pipe at the back of the inlet cos the oil cooler had moved but if your going n/a i dont think its going to bother you just make sure you have the correct flywheel ,iv a spare if u need it but itll cost a bit to post
mikeymikeyp
Postby mikeymikeyp on Fri Feb 14, 2014 7:26 pm
just noticed it was a turbo just use the oil pressure switch thing that goes to the block for the oil return, i was a zvh so a cvh head on mine like :devil:
mikeymikeyp
Postby rsturbonutter on Sat Feb 15, 2014 12:34 pm
I got a couple of rs flywheels knocking about am I right in thinking that I only need to enlarge the holes to 12mm. Will my alternator be ok or do I need a zetec one have got a rs1800 one available. all water hoses will be fine will they?
rsturbonutter
Postby Smo on Sat Feb 15, 2014 5:36 pm
Flywheel holes need enlarging to 11mm :)
You can use a CVH alternator with a CVH mount, and just swap the pulley. Or you can use the RS1800 alternator but with the Zetec front mount.
Hoses - can't help you there! There are definitely some differences, especially with the bottom hose.
Smo
Postby rsturbonutter on Sat Feb 15, 2014 8:31 pm
Been having a look at the bottom hose it appears the zetec is slightly larger at the waterpump. Will get a reducer of some sort.
rsturbonutter
Postby mikeymikeyp on Sat Feb 15, 2014 8:43 pm
Iv been using a cvh one mate cos iv a escort water bottle , its only 2 pipes fae the matrix and the rad hoses what rad u going to use zetec ones a bigger one than the cvh and im sure the fans at the back
mikeymikeyp
Postby rsturbonutter on Sat Feb 15, 2014 9:03 pm
I got a radtec escort rs turbo one mate. Should mention mate I got a rs turbo just swapping from cvh to zetec. I bought an engine out of an Orion turbo from passionford a while ago. I have been collecting all the parts I think I need for the conversion for the last couple of months. Just unsure as to how I mount the lump. I am using everything from my current set up except bigger injectors bigger turbo and Graeme goode exhaust manifold. i just in sure of the water piping can I not use my old heater matrix?
rsturbonutter
Postby mikeymikeyp on Sun Feb 16, 2014 1:22 pm
so your going to run the cvh efi inlet that should make it plug n play on that side just really the water pipes thats an issue then your putting it in a fiesta yes are u using a standard intercooler cos it wont fit in next to the escort rad like the cvh turbo fiesta one and u know youll need to sort a mount out check and see if the guys left a engine mount on the donor engine
mikeymikeyp
Postby rsturbonutter on Sun Feb 16, 2014 3:09 pm
I'm using a grs evo3 front mount cooler. I have all the mounts from a scrapped rs1800 to use if needs be
rsturbonutter
Postby mikeymikeyp on Sun Feb 16, 2014 4:11 pm
thats the engine mount sorted then but if you want to use the front engine mount theres a hole or 2 to drill to fit it it didny bother cos the vibratecks keep it prety solid ,,theres a guide on here it might help a bit :P :P
mikeymikeyp
