Dead fiesta UPDATE
Dead fiesta UPDATE
Postby fiestaturbo1984 on Thu Nov 21, 2013 5:36 pm
Hey guys. I have literally had my rs for about 3 days and done 6 miles. On the way home it seemed to misfire and then cut out. When ignition is turned on, the fuel pump sounds as if it's priming but doesn't shut off. I have cracked of the nut on the fuel rail and when ignition is switched on fuel squirts out. I have taken out a plug and it sparks on cranking so im a bit stumped as to what it could be.
I have also switched over the yellow relay but to no avail.
Last edited by fiestaturbo1984 on Fri Nov 22, 2013 5:13 pm, edited 1 time in total.
fiestaturbo1984
Your car: CL500, Black Fiesta RS
Re: Dead fiesta
Postby fiestaturbo1984 on Fri Nov 22, 2013 12:09 am
anybody?
fiestaturbo1984
Re: Dead fiesta UPDATE
Postby fiestaturbo1984 on Fri Nov 22, 2013 5:15 pm
Ok so after much faffing around I had a little thought and unplugged the "powerchip" from the ecu. Started up straight away :o
I am now under the impression that this chip is pants, I have re-installed it as the car is running beiges and I dont want to risk running too rich or lean.
What are my best options in terms of replacement of this chip. I don't want to go all out expensive management change as i'm not even sure I will keep the car once my little one arrives.
fiestaturbo1984
Postby fiestaturbo1984 on Tue Nov 26, 2013 12:51 am
93 views and not 1 bit of help or advice?
fiestaturbo1984
Postby RS EDDIE on Wed Nov 27, 2013 7:33 pm
The 195 chip ( i take it you have?) is not a good chip for the car and beiges can massively overfuel. I think that if youve got a 165 chip on beiges then its maybe an overfuelling problem.
Also you should only get a Prime of a few seconds then the pump should shut off as it has reached its running pressure. It could point to a faulty pump or pump relay perhaps aswell.
You need to strat from scratch with what pump your running, what bhp chip and what the injectors pump. Then try the pump relay!! :D
RS EDDIE
