Decent Mk3 weld in cage
16 posts • Page 1 of 1
Does anyone on here have a decent quality weld-in cage in their Mk3?
Where was it from and what did it cost? Pictures would be great!
Mark
Mark
Re: Decent Mk3 weld in cage
I do, Steve (pve) did it.
- ~nomad~
- Your car: Breadvan
Havent got one, but I would have it..
http://www.customcages.co.uk/
Think its around 650 to buy it and then you fit it, or around double that for them to fit it.
- happypaul
Custom Cages would be the people to go to for sure... they have plenty of options from mega FIA spec items to smaller 'kit' items - so if you just want a basic 6 point cage with door bars and a rear diagonal you can have it...
Have had a couple of kits from them to fit in to other cars (couple of tigra's mainly) and the quality is awesome - difficult to get right but well worth it in the end!
- AlfaLima
AlfaLima :Custom Cages would be the people to go to for sure... they have plenty of options from mega FIA spec items to smaller 'kit' items - so if you just want a basic 6 point cage with door bars and a rear diagonal you can have it...
Yeah I should have said above..they do whatever you want.. Like AlfaLima says, if you want 6 point cage with door bars and diagonaland maybe a random other bar for harneses, they will do it
- happypaul
Thanks chaps, those cages looks very well designed. I'll drop them a line!
Excursion :Thanks chaps, those cages looks very well designed. I'll drop them a line!
Thats fiesta one above, you need to cut the roof off like shown in the picture to weld it
- happypaul
happypaul :
Correction... to weld it properly.
Unless its going to be scrutineered for some form of motorsport you will get away with welding as far around the joints as you can possibly reach - cutting roofs / changing roof skins can get very expensive very quickly!
- AlfaLima
AlfaLima :happypaul :
whats the point in having a cage if its not going to be installed properly, if it is not fully welded then if the worst does happen and its needed it could turn from a safety feature into a death trap very quickly with the sort of forces that are normally absorbed by a well built roll cage!
changing a roof skin isnt the hardest job in the world its just a bit time consuming to get it all done and for the sake of a properly welded in cage no hassel at all if you do ever need the thing.
- xrsi
- XR(ustyAtTheMo)SI
Captain Tightpants :It is possible to weld that without removing the roof skin.
Steve
I would struggle I think lol.
But fair enough
- happypaul
Steve
I thought this aswell, but removing the skin would make it a bit easier
- Ruishy1
Ruishy1 :Captain Tightpants :It is possible to weld that without removing the roof skin.
Steve
It would certainly be easier, and probably better for a competition car. But it is possible to leave it there and weld it fairly easily. It just takes a very short TIG torch!
Steve
- Captain Tightpants
Custom cages are whom you need to speak with.
I have a variation of a cage they do as you can spec which pieces you want, or go for the whole cabooodle.
- luca
I've had my my shell apart at most of the seams and re-engineered it to fit this underneath:
The roof skin won't present me with a big challenge
Thanks for the input, guys.
