differences between
5 posts • Page 1 of 1
differences between
1.1 and 1.3 hcs engines? im wanting to convert to 1.3 as my current 1.1 is leaking oil from either the sump gasket or crankshaft seal and leaks water out the exhaust. what do i need to swop i need to change block and head but what about ecu, inlet manifld, exhaust manifold, wiring loom etc?
thanks
thanks
At least i dont drive a saxo!!
- Marc D
- Your car: fiesta xr2, xr2i and rs turbo
The blocks themselves should just bolt straight in - one is a longer stroke version of the other iirc - we had a 1.1 for a couple of months. Carbs will just bolt on i'd think, they're not performance models - i'd also think that the Fi would bolt on - maybe a different ECU for a 1.3?
- MotorcyclesFish
- Your car: 2004 Z4 3.0i SE
Car: 1984 Ford Capri
What happened about sticking the 1.6 CVH engine in it? I put a 1.3 engine in my 1.1 SX fiesta, but mine had a carb. I'd have thought you would only have to change the ECU to the 1.3 one and everthing else should be OK. You may have to change to the 1.3 CFi unit also, but the exhaust manifold, inlet manifold and loom should be the same.
Hope this helps ya
Hope this helps ya
- krsi
