digi cam
Items for sale that aren't car parts - phones etc
digi cam
Postby nickyg on Mon Jun 21, 2004 12:20 pm
would anybody be interested in a sony digi cam??? its a cybershot DSC-P72 with a 64meg memory stick. these retail at £200 so im open to sensible offers. btw, i cant find the charger for it, but i will look for it if someone is interested. it takes normal AA batteries aswell and the rechargable ones will also come with the camera. usb cable and software also included.
some spec:
1/2.7" 3.2 Megapixel Effective Super HAD™ CCD
Super HAD (Hole Accumulation Diode) CCD’s provide excellent image quality by allowing more light to pass to each pixel, increasing sensitivity and reducing noise.
• 3X Optical Zoom Lens
To help frame your shots for better digital pictures. Optical Zoom helps you bring distant subjects closer & pull back for wide shots.
• 0 - 3.2X Smart Zoom (at VGA Size)
Smart Zoom intelligently uses the full CCD to let you zoom into the portion of interest by cropping the image size—thus avoiding the image degradation of Digital Zooms.
• Auto Daylight Synchro Fill Flash
If the Multi-Pattern Measuring system determines the subject is backlit or in shadow, fill flash automatically fires to provide optimum exposure.
• 14-Bit DXP A/D Conversion
Sony’s 14-bit Digital EXtended Processor captures the range between highlight and shadow with up to 16,384 values, for extended dynamic contrast and detail.
• 1.5" LCD Monitor
Monitors the scene for accurate framing. 123K pixel and anti-glare coating help provide excellent viewing and image playback clarity, even outdoors.
• True Zoom Optical Viewfinder
Provides accurate framing at eye level, great for added stability and following fast moving subjects.
• Pre-Flash Metering
With a momentary pre-flash, the camera illuminates the subject and sets exposure through the lens for accurate flash metering. Adjustable flash level and redeye reduction insure great flash shots.
• QXGA (2048 x 1536) Image Size
With its high resolution CCD, the DSC-P72 captures in 4 different image sizes, with selectable Fine or Standard JPEG compression.
• Multi-Burst Mode
Captures 16 320x240 frames as part of a single 1280x960 image which plays back sequentially in the camera. Selectable 1/7.5, 1/15, 1/30 second frame intervals provide convenient motion analysis.
• Clip Motion Mode
Capture up to 10 images and convert them to an animated GIF with 2 fps playback. By varying the interval between shots you can create animations not possible with other motion capture modes.
• Playback Zoom, Trim and Resize
During playback, magnify any portion of the image up to 5X and trim to the area of your interest. Then, save the new image as a new file in any of the image sizes available from the menu.
• Rechargeable NiMH Batteries
Long-lasting power is provided by 2100 mAh rated Nickel Metal Hydride (NiMH) Stamina® batteries with BC-CS2 external charger. Or, choose "AA" Alkaline cells or optional AC adaptor.
nickyg
