Disconnecting map sensor
Postby farleyj on Tue Apr 09, 2013 8:06 pm
if i unplug my map sensor on my frst nothing seems to happen!!! is this right or should something happen???? only asking because my car will no rev when accelerator is pressed so im thinking map is knackerd. any help would be great. thanks
farleyj
Your car: 91 frst nova gsi transit conn
Re: Disconnecting map sensor
Postby FRSJON on Tue Apr 09, 2013 8:46 pm
id of thought the only thing that would happen would be the revs rising due to the air leak. nothing else would happen until you drove it on boost then it would go bang :lol:
FRSJON
Postby jammy86 on Fri Apr 12, 2013 9:20 pm
Are you disconnecting it electrically? What management system? My OFAC setup wouldnt start with the map unplugged.
jammy86
Your car: KaRST
