Do I need to change loom when converting 16v xr2i to a mondy
12 posts • Page 1 of 1
Hi everyone Im getting confused im changing my 16v xr2i to a 2.o mondoe silvertop engine and im aware of the changews that need to be made to make it fit etc but im confused about the loom. One guy I have talked too ran his with the original ecu and loom no problems at all, and others on the site say the loom needs to be changed? Please help many thanks
- lowridermk3zetec
Its only 200cc more so the std loom and ECU will be fine but get it on a rolling road after to seeif the fueling is ok
- freak power
The xr2i runs external EDIS and the Mondeo ECU's ahve internal EDIS so the mondeo ECU wont work with the 2i loom. You could change over to the Si loom which has internal EDIS or you will have to use an RS1800 ECU.
- Raymondo
s'up to you mate
i ran a 2.0 ltr with a 1.8 RS1800 management (ie loom and ECU) then changed it to a full si loom with 2.0 ltr ECU.
The latter was a 100% improvement
Renault Sport Megane 250 Cup
Ford Fiesta XR2i 2.0 trackcar
- Project_XR2i_Trackcar
- Your car: Xr2i
getting mixed opinions here, if I was to use the original loom for a small amount of time would it be ok and if so what ecu would I need to use? Could I use the 2i loom and ecu to get her running ok?
- lowridermk3zetec
Well i'll say it again for the hard of reading
I ran a 2.0 ltr with a 1.8 RS1800 management (ie loom and ECU) then changed it to a full si loom with 2.0 ltr ECU.
It ran with the 1.8 management (ie RS1800 ECU, 1.8 injectors and 1.8 16v external EDIS loom hard wired into the existing 8v car loom, modified 2.0 ltr throttle body and a 1.8 MAF in a 2.0ltr MAF housing) but, it was ropey as hell so.....
i sourced a complete 1.6 si 16v loom, changed the entire loom (ie car and engine loom), used a 2.0 ltr DEEP ECU with matching 2.0 MAF and 2.0 ltr injectors.
Now runs like it should, smooth and bloody quick.
- Your car: Xr2i
use an Si 16v loom with a deep, desk or dewy 2000cc ecu and 2000cc brown injectors, sorted
dont use rs1800 ecu's.. its worse than smoking..
- JayC
ok cool how hard is it to change the loom as this is the only part that im worried about! All other bits seem fine and im doing all that tomorow but ive never done a loom before. How long does it take to do and do roughly? Also how do I know what ecu to go for as Ive brought the engine minus loom and ecu?
- lowridermk3zetec
- JayC
