Door Hinge Pin tool..
9 posts • Page 1 of 1
Anyone link me to one that'll work on the MK3?
Cheers in advance
Cheers in advance
- Fraggle
Re: Door Hinge Pin tool..
soak in wd40 overnight then......Long flathead screwdriver and hammer!!
- RS EDDIE
get a blowtorch and give them a heat then hammer n chisel but they do snap mate ,just try not to bend the hinge on the car
If your scrapping the door mate might be easer to get in with the door grinded off
- mikeymikeyp
Cheers lads...
EDD ive done WD since i bought it lol, they are pig baxtard tight, ive a crow bar to try next
Mike... Ive got new Pins anyways(hope they fit lol)..and im keeping the door...
Again they are fkin in there, might try the heat bit...
Cheers mate i 4got about me blow torch
- Fraggle
I've used a proper ford tool before and it's a pain, I norm use a big chisel and a club hammer.
If your lucky they won't take much beating to get out and the pins can be reused, believe it or not I found a 4 door at the scrappy once and had 3 doors off within 5 mins only wanted the pins not the doors, the 4th door wouldn't budge.
On the other side of that, I've also had to get the oxy acetylene out and heat the whole hinge part until its glowing orange and beat the living fcuking $hit out of it to get the pin out.
The hinge on the car should not move, the door part shouldn't, but be carful and allow it to cool so it's not glowing before showing it who's boss.
Be prepared for a pin to come out in 2 maybe 3 bits, as they do sheer over the years, and what ever way you do it I expect the pins to be naffed at the end of it
CheeRS jay
Im Desperate to get the buggers off, ive got [ERRR] pins..hopefully they are right size...
Also im collecting my modified jig brackets tomorrow, wanna make the shell light as poss incase the father in laws welds aint too sharp
- Fraggle
Lol
All I can say mate is good luck with it, hopefully yours will come out easy.... Fingers crossed
interesting thread as im looking at fitting two doors to my fez this year, never liked it with no handles
- crazycage
The easiest way doin these is with a air chisel and heat
Shaun
Shaun
- shaunrs
- Location: wolves fc- drives fiesta2.1 zetec turbo wanting a gt28 turbo badly
- Your car: i get a lift to work
