DOT 4 Brake Fluid
4 posts • Page 1 of 1
DOT 4 Brake Fluid
Hi there,
This may sound a really stupid question to all experianced members but I just wanted to double check.
I´m getting new brake pads and discs next week, and was also going to get DOT 4 brake fluid.
Lookign around there are so many types.
Could somone simply post the right fluid just enough to do both front sides, and its for a 1995 1.3 non ABS car.
Many Thanks,
Scott.
Many Thanks,
Scott.
- funkdude2
DOT 4 is the correct fluid you should be using. If you haven't already though it's worth flushing the whole braking system through with fresh fluid as over time it absorbs moisture from the air which lessens it's effectiveness as the boiling point lowers.
Ideally you should be changing brake fluid every 2 years anyway.
Re: DOT 4 Brake Fluid
ok great!
Could someone possibly provide me with a website link to the correct type my for non ABS car.
like i stated before i have seen so many versions.
Thanks.
Thanks.
- funkdude2
Any Dot 4 will do, if you want the best try n find Castrol Response Super Dot 4
No Filler Nova Killer - Goes Like A Bomb
When I'm not here I'm somewhere else
- Maff Si
- Your car: Nothing til end of the month
