driveshaft noise!
8 posts • Page 1 of 1
driveshaft noise!
Wonder if anyone can help. Everytime i go round a corner theres a rattling noise coming from the O/S front wheel, so i took the wheel off and found the drivshaft was moving in and out, approximately 1/4 of an inch of play!
Just wondered wether anyone had had a similar problem.
i.e, the wrong driveshaft is fitted or its not fitted properly etc
Would a frst driveshaft fit as i hav one laying around? Any help would be grateful
- gatman
driveshaft noise!
Sorry forgot to mention its a mk3 fiesta fitted with a 1.8 16v zetec
- gatman
sounds like a CV joint, you need to twist the shaft and see if there is any play you always get a bit of in and out movement, as for the turbo shaft if will be ok on the inner side its just the outer joint depending on the hub size.
- FRST5090
driveshaft noise!
Ha ha ha
After checking the driveshaft and thinking that there isnt much play really i had a look in the other obvious places i got hold of the header tank and found it wasnt bolted down and was just flapping around in the wind
I feel a gammon slipper
Cheers anyway
Cheers anyway
- gatman
driveshaft noise!
Yeah thats the main thing. Easy fix
- gatman
