Dual sub scenario :-)
4 posts • Page 1 of 1
The only ICE I have in my car is a cheap-n-cheerful CD player which has 2 RCA outputs (and the usual ISO one).
My aim is a boot-build, including 2 subs.
I don't know too much about amps, subs, and wiring - so be easy on me
Question: How can I run 2 subs (10"), and 2 6x9's from ONE set of RCA plugs?
Can you string amps together, or run them parallel?
I'm kind clueless!
It's all theortical atm, as I don't have the money to buy it - just doing my homework before I do
I'm kind clueless!
Do not underestimate the power of a 1.3 - It's low enough already
- xiphon
by a 2 channel amp with 2 rca slots and get a set of splitter rca leads basically one in to, two jobby for about 7 quid i think, and should be able to run both channels then, amping 6x9s is pretty pointles and 6x9s in a hatchback is pretty pointless with subs they interefer with each other
Get your PHD, in Breastating, apply with in for more details
- pitslayer
I'm going to use an in-car PC to supply the tunes
It'll be a mini-ITX [fanless 1GHz] system, with a 24-bit Creative soundcard, and a touch-screen USB monitor...
Budget won't be too high - I don't want a powerful system - just something which gives a nice subtle boom when in the car.
- xiphon
