Eagle steel con rods
6 posts • Page 1 of 1
http://cgi.ebay.com/ebaymotors/Ford-Foc ... enameZWD2V
These work out at 180 pounds, i've seen a lot of people use these rods, so whats the catch? Which shells would i need to use with them? Thanks
oh hoh
- demolition_man
There's not a catch with these rods, IIRC the forgings are made in China and the machining is done in America. Bear in mind you won't get them for £180, you'll have to add shipping, duty at about 4% and VAT on the whole lot.
- sailorbob
arent they the shorter series 3 zetec rods?
JJ
JJ
Is that the best you can do?
- jdfiesta
- Your car: V70 T5
These are 5.483" c-c, the ones in burtons are slightly shorter they list Farndon rods for the early zetec at 5.36" c-c so I would think there is a difference in length, but if the B.E and S.E sizes are the same Im sure you could machine the piston crown to the desired compresion ratio (forged pistons with unfinished crown)
I was looking into these but didnt want to shell out another £500 on pistons to fit these
- robbie s
robbie s :These are 5.483" c-c, the ones in burtons are slightly shorter they list Farndon rods for the early zetec at 5.36" c-c so I would think there is a difference in length, but if the B.E and S.E sizes are the same Im sure you could machine the piston crown to the desired compresion ratio (forged pistons with unfinished crown)
i am currently using these rods in my zvh with je pistons but i had to use a de-comp plate because my comp ratio with the cvh 57cc head worked out to be 8:4:1, so i used a 1.2mm plate to give me a comp ratio of 7:8:1. due to the boost i want to run and the fact that the pistons i used crown were quite thin i could only take 1mm off the top. i brought my rods and pistons from here http://www.nolimitmotorsport.com
gt 2876r aka gt25/40r roller bearing turbo, L8 ecu, 850cc injectors mapped by msd to 12psi with LC & AL closed loop 30+ psi soon
0-100 10.84 100-150 9.24 154mph daddy thrash 06
- turboboss
