EBC Brakes
5 posts • Page 1 of 1
EBC Brakes
Just wanted to know if its worth using these crossed drilled discs with Green Stuff Pads ..... Driving a xr2i only driving on road
- adzxr2i
- Your car: xr2i
Re: EBC Brakes
Wouldnt bother with drilled discs, as you will see no benefit. The greenstuff pads are fine for road use, but can wear down a little quick. Personally id go for some Ferodo ds2500 pads or Mintex 1144's.
- hb69
- Your car: Fiesta 1.1 LX
Re: EBC Brakes
As above never rated the EBC stuff much and on a road car not worth it drilled discs will just give less braking surface area on a road car used for track/race cars to get rid of the gasses caused by the constant high heats
- allinking
Re: EBC Brakes
Thats what I thought thank you both for your help ....
what about the green pads EBC on standard dics would that be okay
- adzxr2i
- Your car: xr2i
Re: EBC Brakes
Yeah, they will be fine. But as said id recommend the ferodo or mintex pads over the green stuff.
- hb69
