Economical brake upgrade for my frst
10 posts • Page 1 of 1
can anybody give me some suggestions as to how i can upgrade the brakes on my frst?? only got standard ones at the mo with drilled and grooved discs
any help would be great
Kind Regards
Raj
Autoflock MotoRSport
Electrostatic Flocking & Powdercoating - Carbonfibre Composites - Blast Cleaning
http://www.autoflock.co.uk - info@autoflock.co.uk - http://en-gb.facebook.com/pages/Autoflock/138838679528652
Raj
- Autoflock
Re: Economical brake upgrade for my frst
go for the tried an tested 4x4 cosworth calipers, discs and pads
- Ruishy1
Ruishy1 :go for the tried an tested 4x4 cosworth calipers, discs and pads
thanks very much ruishy, was begining to think i was on my own here.lol
will they just bolt straight on??
Kind Regards
Raj
Raj
- Autoflock
Cosworth ones will do yes but you'll need some spacers (I used washers) to go between calliper and hub.
- Tweek
- Your car: VW Golf GTD
What about some Brembo's? See the For Sale section
- jmeBDC
ST150 brakes go straight on.
- fiend
fiend :ST150 brakes go straight on.
Would have been my suggestion
- M1K3Y_B
Car: 1996 Ford Fiesta Classic
jmeBDC :What about some Brembo's? See the For Sale section
hardly an ecomnomical upgrade is it
- Ruishy1
Ive got Mk5rs2000 discs(260mm) with mk1 mondeo calipers and pads. no spacing needed at all. Just the mounting holes need drilling out for the bigger bolts
- Ratspeed
get mondeo st24 2.5 v6 calipers same as cossy but cheaper try first for spares in garstang we deliver them to and would throw in the disc if u ask and they fit straight on all u will need it if its a mk3 then u may need to drill the caliper bolt holes on the hub as theyre smaller on the mk3 and ull need 15" 07918731148
- HCS PIMP
