ECU + Superchip
5 posts • Page 1 of 1
ECU + Superchip
Can someone tell me an easy way to remove the ECU and then where does the Superchip plug in?
I have a 1.6Si 16V 95 Fester
Cheers in advance
Cheers in advance
Lower than a snakes bollox
- Big Walker
- Your car: Seat Ibiza
you dont have to take the ecu out,
look underneath the dash on the passenger side
and you'll see the ecu closest to the wing, on the back of the ecu is a plastic guard, that comes off and you plug the chip in there!
make sure you clean the pins as they should have grease on them to protect them!
- RS rob
I recommend taking the ecu out, you cannot clean the J3 connector (the part of the circuit board that forms the edge connector for the chip) properly without removing the circuit board from both halves of the case.
- sailorbob
But what is the easier way to take the ECU out???
- Big Walker
Thanks guys i have seen the place for where the superchip goes
Was actually so simple
Didn't realise that wa it at first bcause of so much grease
Thanks a lot guys
Thanks a lot guys
- Big Walker
