edis4 and esc module question
Postby bretjaso07 on Sun Jul 14, 2013 11:15 pm
hi my car is a xr2i 16v with a 2.0 silvertop mondeo engine fitted running edis4. im fitting bike carbs and need to know if i can just unplug the edis and plug in a esc module using the edis4 wiring loom and plug? do all the wires go to the same places?
bretjaso07
Your car: FXRT
Re: edis4 and esc module question
Postby bretjaso07 on Mon Jul 15, 2013 5:20 pm
Bump ... Any help ?
bretjaso07
Your car: FXRT
Postby georgiocat on Fri Jul 26, 2013 5:18 pm
EDIS can be run completely stand alone.Since you already have the crankshaft sensor,nothing more than the EDIS module and a coilpack is needed.Use this schematic
You just don't use PIP and SAW wires,these go to the ECU.
My Ford Escort ride
georgiocat
Postby waxdaddy on Sat Jul 27, 2013 7:36 pm
georgiocat :EDIS can be run completely stand alone.Since you already have the crankshaft sensor,nothing more than the EDIS module and a coilpack is needed.Use this schematic
I'm guessing he wants to use the ESC module because it provides a MAP sensor which allows for vacuum advance when used on a carb'd zetec... or at least thats why I used it on my XR2
waxdaddy
Your car: Fiesta RS1800
Postby waxdaddy on Sat Jul 27, 2013 7:59 pm
waxdaddy
Postby georgiocat on Sun Jul 28, 2013 10:03 am
Oh,my bad then.I didn't know that esc has a map and can alter advance...very interesting.Sorry if I confused you further...EDIS can't alter advance,it's true,unless you find a way to feed it with SAW signal.
My Ford Escort ride
georgiocat
