efi inlet : Technical Problems / Queries | Fiesta Forums
efi inlet
efi inlet
Postby doRSet lee b on Wed Jul 17, 2013 2:35 pm
Hi people,
Got an efi inlet and wondered if its the correct one i need for my zetec turbo conversion. im going to be running ofab system. The inlet looks the one pictured below. help would be much appreciated.
doRSet lee b
doRSet lee b
Re: efi inlet
Postby russ-RST on Wed Jul 17, 2013 5:28 pm
Yea that's the right one fella you will need adaptor plates for It to fit to the zetec engine tho. Plenty of other options to go for if you don't want to use this design, apparently they aren't a very good port match to the zetec engine
russ-RST
Your car: fiesta rs turbo
Re: efi inlet
Postby doRSet lee b on Wed Jul 17, 2013 8:07 pm
Cheers buddy.
want the cheapest method really.
Can you tell me what the bit/part on the drivers side of the inlet is on some castings but this hasnt got it.?
doRSet lee b
doRSet lee b
Re: efi inlet
Postby FRSJON on Wed Jul 17, 2013 9:00 pm
doRSet lee b :Cheers buddy.
that would be the idle speed control valve. the inlet you have pictured is for a remote idle valve.
FRSJON
Re: efi inlet
Postby doRSet lee b on Wed Jul 17, 2013 9:24 pm
FRSJON :
Thanks. So i will be ok to run ofab system. just got to find an remote icv.
doRSet lee b
doRSet lee b
Re: efi inlet
Postby FRSJON on Wed Jul 17, 2013 10:15 pm
yeah no probs. you need the same valve bolted to the other style inlet ,later efi cars in the ford range have the remote valve on a bracket near the bulk head.
change the xr2i air temp sensor you have in your inlet to a rs turbo item.
FRSJON
Re: efi inlet
Postby doRSet lee b on Wed Jul 17, 2013 10:23 pm
Ok cheers. All gets a bit confusing but i will get there.. thank you for the help.
doRSet lee b
doRSet lee b
