efi,mfi
7 posts • Page 1 of 1
efi,mfi
hi will an escort turbo head go straight on a fez turbo
cheers matthew
cheers matthew
- Straight882003
- j7aoc
cheers 4 that pal so is the addaptor plate for the injection manifold if so this is the only bit needed to put an escort head on my fez turbo
cheers matthew
cheers matthew
- Straight882003
The head is shaped differently on the inlet side to allow the positioning of the injectors.
As J7aoc says you can buy an adapter to allow the EFI inlet to be used on the MFi head. This can cause problems with clearance (which is tight in the Fiesta bay anyway. Probably do better to source a repalcement EFi head. Any FRST/XR2i item will suffice as they are the same, probably be cheaper than the plate as well.
hi fella can u garantee that an XR2I head will fit straight on my fez turbo as there is 1 in my local paper stage 2 for 100 quid let me know asap cheers matthew
- Straight882003
The FRST item is absolutely the same as the standard XR2i item.
I can't guarantee however that a worked XR2i head will work properly though. What works on a normally aspirated engine to help things along won't necessarily help on a turbo engine.
