EGR valve
14 posts • Page 1 of 1
Re: EGR valve
On a standard or mildly modified engine you will lose some economy if you remove the EGR.
- sailorbob
Re: EGR valve
will i gain power tho? isthis an easy mod
- bankxi
Re: EGR valve
There's a guide in the Guides / FAQs Section
search for pulse air system or blanking plugs and you will find it!
I had a spare zetec escort manifold that I swapped for my one with EGR
No Filler Nova Killer - Goes Like A Bomb
When I'm not here I'm somewhere else
- Maff Si
- Your car: Nothing til end of the month
Re: EGR valve
You won't gain any power by removing the EGR.
- sailorbob
Re: EGR valve
so if there is no preformance gains why do people do it?
- bankxi
Re: EGR valve
From what I have seen throttle response is improved, as is some mid range torque. Does seem to vary from car to car though with some having a notable effect and others virtually no noatable difference
Re: EGR valve
i removed the egr from my 2.0 a few days ago and can confirm it improves the throttle response. i have no idea whether it increases bhp or not, but for the sake of a few quids worth of washers and bolts its one of the cheapest and easiest mods ive done so far
- hb69
- Your car: Fiesta 1.1 LX
Re: EGR valve
sounds good to me ill be doing it lol
- bankxi
Re: EGR valve
You might find that 'improved throttle response' you are feeling is down to too much spark advance (the ecu runs more advance when EGR gases are added). These leads to a couple of thoughts, firstly you might get pinging because of the advance being wrong, and, secondly, the ecu might drop this additional advance once it figures out the EGR isn't working and you'll be no better off.
- sailorbob
Re: EGR valve
I would think it would run with more retard with the EGR connected due to the dirty gasses being put back through the system. Not found any issues on the dyno with EGR's being blanked off and certainly not experienced any pinking
Re: EGR valve
EGR lowers the combustion temperature (hence the reduced NOx emissions) and slows the burn rate which results in the need for more spark advance.
- sailorbob
Re: EGR valve
With the hangover I have I can't even begin to try and think about technical stuff. As said though we've not experienced any pinking issues on cars that we have removed the EGR from
Re: EGR valve
why would tubukar manifolds be fitted if it cause pinking dont be silly have a bud and go to bed
- HCS PIMP
