Electric problem with my ZS...?
12 posts • Page 1 of 1
Hi guys,
Just need some help really. The brake light bulbs needed changing so I replaced the bulbs.
Ever since replacing them with new ones the brake lights have worked but the rear lights haven't.
Unsure what has happened and unsure what I've done to make the rear lights not to turn on?
Might be something simple but I've never come across this before and I'm awful with electrics.
James
James
- EUFez
Re: Electric problem with my ZS...?
Did you check the fuse? If you accidentally hit the bulb holder off the body etc you could have shorted out the fuse, worth a look anyways
- Dave5300
Dave5300 :Did you check the fuse? If you accidentally hit the bulb holder off the body etc you could have shorted out the fuse, worth a look anyways
I've looked at the fuse located in the dash. Looks ok to me...
Unless the fuse is located in the engine bay? Sorry, no good at these things lol
- EUFez
Ford put the front and rear left light on one fuse, and the front and rear right on seperate fuses, so if a fuse blows I'll still have one bulb working, sounds strange.
- EUFez
Were they combined brake and rear light bulbs and you possibly fitted single 21w bulbs by mistake?
- rs220bhp
Shouldn't be dual element, should be single.
Are they LEDs?
The bulb holders use a common earth. Is the bulb holder actually getting power when the lights should be on?
(It's reverse polarity, so the earth is the bottom pin, and the live will be the outter)
Are they LEDs?
- trecoll
They are not LED's. Just a normal halfords bulbs. As said the Brake lights do work. But the rear lights do not turn on? The fuse is blue 15 under the dash right? So I thought anyway. Fuse looks ok to me. It's a strange one, and really need it sorted before the MOT!
- EUFez
I would check all the fuses mate, only takes 5 mins, I've got a zs and sometimes it's not always the fuse it says it is!
- ZetecsTurbo
- Your car: Mk5 Zetec s
Yeah, you're right. Gonna have to check all of them over the weekend. Cheers guys!
- EUFez
trecoll :The bulb holders use a common earth. Is the bulb holder actually getting power when the lights should be on?
- trecoll
trecoll :trecoll :The bulb holders use a common earth. Is the bulb holder actually getting power when the lights should be on?
Well it must be getting power as the brake lights work? Obviously the it's the same bulb. It's just the rear lights do not turn on when I switch it on dipped beam and full. Strange, as I've checked all the fuses under he dash. They look all fine. Hope it can be fixed!
- EUFez
But it's not the same bulb. It's the smaller one next to the brake light bulbs.
- trecoll
