Electrical problem on ICE
Postby enve19 on Thu May 24, 2007 5:59 pm
I decided to install all the system into the car today.
Got a cheap box off a friend til i get a Bassboy special!
I have got everything running in the car sub, amp etc.But if i turn up the stereo too high or increase the bass the amp cuts out saying it is because of excessive current. Could this be caused by a loose connection to the battery terminal, as i have noticed the power cable going to the lug on the battery terminal seems a little loose and with a good pull could come out.
Any help will be truely appreciated.
enve19
Postby enve19 on Thu May 24, 2007 9:34 pm
Right replaced the loose connection on the battery terminal and still the same thing.
Checked the ampage on the amp and it runs steady at 1amp on low volume, as soon as you crank it up it peaks out at 28amps and shuts off.
Is it a possibility that the ground is not thick enough considering the power is of high gauge?
Or am i looking at a fooked amp?
enve19
Postby mikeysabes on Thu May 24, 2007 11:01 pm
Should give me a try on ur box mate :D
we have a place that do all our custom boxes, and built in the UK
there really good, no one has ever complained about them, they all love um and reckon we have given the best quote
either sealed or slot ported, if the subs a monster there double thickness too,
Mike
mikeysabes
Postby mikeysabes on Thu May 24, 2007 11:02 pm
Mike
mikeysabes
Postby enve19 on Thu May 24, 2007 11:36 pm
Well at the mo, i might have stick wit me box and buy a new amp with me money!!
Really starting to do me swede in now cos i wanna crank it up and i cant
enve19
Postby enve19 on Thu May 24, 2007 11:53 pm
This is what ive been told as a possibility
"that you're hooked up to a load impedance that's too low. This can be caused by improper subwoofer wiring, loose or shorted speaker wires"
I'm pretty sure i have the sub wired correctly, as follows;
positive to positive bridged and the same for the negative. Then separate cables running to the amp from one of the negatives and positives. Making it 2ohm
http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?suboptions=Mono%5F1%2D4ohm%2DDVC&amptype=mono
The amp says i can run it at 2ohm.
enve19
Postby mikeysabes on Fri May 25, 2007 10:40 am
What subwoofer and amp are you using mate ?
mikeysabes
Postby enve19 on Fri May 25, 2007 11:19 am
It is an Alpine 1241D Sub Dual 4ohm and an Alpine MRD M500 amp
As i say got it wired to 2ohms as in the picture.
enve19
Postby bassboy on Fri May 25, 2007 3:40 pm
ur getting too much current into the amp mate....change the earth point or try running thicker cable into the amp and earth and see what it does
bassboy
bassboy
Authorised Trader
Authorised Trader
Postby enve19 on Fri May 25, 2007 4:31 pm
Cheers fella
I have the Earth running to the negative on the battery as its close, this is my problem isnt it?!
Im not being a Judas, its something to get me by til i take delivery of a special of yours!!
enve19
Postby bassboy on Fri May 25, 2007 6:50 pm
hmm try getting a thicker earth...and try earthing it to the body...i know the problem u have as it happened to an Alpine F345 when i done an install in my mates car - Alpine 9583, Infinty Perfect 6.1 front and rear, Alpine Type R 12" sub in my own custom made box, Alpine F345 and Directed D750 IIRC...all supplied and fitted by myself and after a while the amp used to say CUR....rang up Alpine rep, and he said to try what i said and it cured the problem (tried another amp and it done the same thing)
bassboy
bassboy
Authorised Trader
Authorised Trader
Postby taylor5788 on Sat May 26, 2007 1:12 am
first off, that link was for a single sub, youre using 2 so http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?amptype=mono&suboptions=Mono%5F2%2D4ohm%2DDVC might help. if not then use http://www.restricted.alpine-electronics.co.uk/support/ownersdatabase/SWR-1241D/OM_SWR-1XXXD_EN.pdf courtesy of Alpine Audio Europe :lol: cant be wrong there, although i wired em different when i had em.
i hope your using the wiring kit i supplied :lol: if you are then its something youve done when wiring it.
have you got all the 3 in line fuses in? did u check the terminals in the dist. block?
taylor5788
Postby taylor5788 on Sat May 26, 2007 1:14 am
and wire the earth to the chassis not the battery neg
taylor5788
Postby taylor5788 on Sat May 26, 2007 1:18 am
mayby give the power cable a crimp on the battery end, the terminal is gold plated and cost me £8 lol
taylor5788
Postby enve19 on Sat May 26, 2007 7:28 pm
im only using the one sub, so the diagram is correct.
Have changed the ground, took some of the 4awg power cable and used it as the ground. I've also made sure the gain and other settings have been set to 0.
The volume can go a little louder now but not a great deal.
Gonna try another amp soon and see how i get on.
Thanks for the advice so far.
enve19
Postby bassboy on Sat May 26, 2007 10:30 pm
Karl mate...if there is any chance u can come see me ill test it out on our test rig if u want? im sure its nothing to do with the amp though...i could be wrong though
bassboy
bassboy
Authorised Trader
Authorised Trader
Postby enve19 on Sun May 27, 2007 12:31 am
Nice one fella, that would be most appreciated.
Can probably get down end of the week, friday im about.
Would do thursday but its shopping with a female, so i'll be tied up in that all day!!!
enve19
Postby taylor5788 on Sun May 27, 2007 12:31 am
cant be the amp, i used it powering BOTH subs for 2 years and my mate did the same before me for another 2 years roughly.
how comes your only usin the 1 sub? try it with both of em
taylor5788
Postby enve19 on Sun May 27, 2007 12:39 am
Only got the single 12 box at the mo.
Gonna let bassboy have a butchers at the set up, it may be me setting it up in a shoddy manor!
enve19
Postby taylor5788 on Sun May 27, 2007 12:40 am
lol ah i see
give it a go with both subs without the box obv but tilt the subs so you dont block the holes on the bottom then that should help ya somehow :lol:
taylor5788
Postby enve19 on Tue May 29, 2007 10:53 am
Solved it!!!
Although it says 2 ohm stable, it obviously didnt like it.
I have downed it to 8ohm and what do you know, the thing goes up and up and up!!
Just need to change the settings on the amp and i'll be sweet.
enve19
Postby taylor5788 on Tue May 29, 2007 6:11 pm
ahh you see lol
might i reccommend some sound deadening though, my fiesta sounded like it was gonna fall apart with the subs
oh and a good game to play is see how many car alarms you can set off. i did that down the sea front, let off about 9 in 2 hours or summit :lol:
taylor5788
Postby bassboy on Wed May 30, 2007 12:18 am
does the sub play as loud now you have it like you do?
taylor...9 in 2 hours? try 9 cars in a row while driving past them :lol: :lol: :lol: :o :o
bassboy
bassboy
Authorised Trader
Authorised Trader
Postby enve19 on Wed May 30, 2007 8:54 am
Nah nowhere near as loud.
I pressume its because at 8 ohms its underpowering the sub now.
Gonna try with the second sub wired in so its at 4ohms see if there is any difference there.
Used to go in the multi storey carpark and it used to set them off like i was jumping on the cars!!
enve19
Postby taylor5788 on Wed May 30, 2007 5:36 pm
this is essex mate youll have difficulty findin 9 cars with alarms! :lol: :lol:
taylor5788
