Engine change question
11 posts • Page 1 of 1
I have bought the GF a 1 litre H reg MK3 fiesta but also have a 1.3 j reg fiesta that failed MOT on body work will the 1.3 engine and gearbox fit stright in to the 1 litre fiesta or is there more involved?
2014 Fiesta ST3 & Mk6 Fez ST
- mrorange2
easy change, aslong as they are both cfi engines not on Carb. swap engines and the ecu and should run ok. Wont see much of a power increase as the 1.1 has about 50bhp and the 1.3 has about 60bhp.
- Andy299
yes youll need fuel tank lines wiring and pump plus all the engine bits and youll notice one hell of a difference
1.6 si coming soon
5 Door Register
5 Door Register
- Gazeddy
H plate is carb, so as above you'll need to swap the entire loom, fuel tank and lines and everythign else you can see.
OR..you could re-jet the 1.1 carb.
yeah that car doesnt need to pass the new emissions rules does it so yeah should be ok
1.6 si coming soon
5 Door Register
5 Door Register
- Gazeddy
- Smo
yeah easier than if its not
1.6 si coming soon
5 Door Register
5 Door Register
- Gazeddy
Smo :You sure the 1.3 isn't carb too? If it's only a J-plate, chances are it is.
Exactly what I was thinking.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
