Engine change
11 posts • Page 1 of 1
Engine change
hi y'all just asking what will be the best engine to swap for my 1.0L fiesta?? its a mk3 and im looking at either 1.6s or mk2 xr2 engines?? please help with info and what ill need to do to fit either of these.. im also looking at getting twins and fast cams or some other tuning items.. whats best there??..
thanks guys+gals.. any help thanked
- smoov_fezzy
would be pretty easy to swap yours for an xr2 engine as they are pretty much the same wouldent need to change much , although with an xr2 engine it would be classed as an xr so insurance would be higher , have to take that into consideration.
cheers mark.
cheers mark.
- pugeyed
ok.. so is a 1,6s harder to fit than an xr engine?? also.. ive heard that liverpool victoria are good with engine changes?? is thid=s true and how much they charge?
- smoov_fezzy
A 1.6S is a late XR2 engine fitted to the mk3 fiesta. If you get one you should try and get an early XR2 carb to go on it (square top iirc) as they give you something like 6bhp.
I read somewhere that L&V only insure engine conversions if that model was made as standard ( ie they should insure a 1.6S into mk3 1.1 as the 1.6S was a mk3 too)
lee
lee
- LeeB
cheers mate.. so the engines are both the same with little differences in the mk3 1.6?.. cheers.. and help on what mods and bits i will need if i buy a doner car?
- smoov_fezzy
Can't help with what parts you would need to swap over I'm afraid. It shouldn't be a problem if you buy a whole doner car and have them side by side though.
AFAIK the 1.6s used up the leftover engines from the XR2's. The early XR2's (C reg and before I think) had a better carb than the C reg onwards XR2's (and therefore 1.6s as well)
Try searching the forum on http://www.xrtwo.com as the mods on the xr2 engine will be the same as on the 1.6s engine. The engine will be like a rocket as standard compared to a 1.0 anyway
lee
lee
- LeeB
- smoov_fezzy
Are you sure it is better?
I mean yeah it produces another 6bhp but maybe they changed it for a good reason, like it was totally uneconomical for example?
- Stoned
Stoned :
I am just passing on the information that I have recieved on other forums when I was researching XR2's. The fuel consumption was never mentioned,just that the earlier carb was the better option.I believe the later carb was used on several different models,so I would suspect that cost was a major influence in the change.
lee
- LeeB
Stoned :I mean yeah it produces another 6bhp but maybe they changed it for a good reason, like it was totally uneconomical for example?
Yeah but given the choice would you have
std carb
twin webbers
economy, power, economy, power...
Nige
'94 mondeo. Pass the mortgage, son.
Hmm... what... eh?
Hmm... what... eh?
- df908
